hi folks
Have just had to replace the bulb in the spoiler, found that you have to remove the spoiler by accessing 4 nuts 2 are found under rubber grommets by the top strut mountings. The remaining ones have to be accessed by removing the top trim on the rear door the use of a 10mm
box spanner is very helpful don’t be fooled by the access panel on the top of the spoiler!
mike
Hi Mike,
Managed to do the same but just by removing  the top trim on the tailgate using very long nosed pliers with angled end. have replaced all the T10 incandescent lamps with led can bus lamps, can send you the link if you want.
Cheers, Clive
I replaced the whole light fitting for an led one with out removing the spoiler, once the top screws are removed the whole light fitting can be removed as it is clipped into the spoiler
