I have bought a spare key, uncut and not programmed. Can anybody tell me the process for reprogramming. I have tried the process on the earlier (not facelift) model and it doesn’t work. Thank you
Hello Martin,
I don't have a 2006 2.4L, but I do have the 2006 3L.
Your keys look nothing like mine, nor do they look like anything those in the Owners Handbook I have (JPNZ).
Are you sure they are the correct keys.
I believed the facelifted version uses the 4D67 chip embedded in the key blank.
Even when correctly cut , without that 4D67 chip it won't start the car.
Hopefully, someone else has the same keys as you, and can help you.#Good Luck.
It is the key with the back removed. The new one does have the transponder chip, the same as the main key. I think the pre facelift version does not have the transponder chip. Thanks for your reply
Sorry, I saw 2006 and assumed you have a facelift.
I need better reading skills.
Even so, the key you have does not appear in the JPNZ Owners Manual.
What does the face of the key look like ?
