hi just replaced 12v battery need to reset windows to all work from drivers door can anyone help thanks
Hi try resetting each window by using its own switch. Put the window fully down by holding the button and once down hold the button for about a further 10 seconds. This should reset each one and this will then let you use the drivers door switch for all windows. Good luck !
Go to each door and lower the window all the way down and hold the switch for 2 secs then raise the window all the way up and hold switch for 2 secs, they will then work from the drivers door
Hi dezufo,
You first wind your windows down off their own switches, straight down and then straight up without stopping, they will work of your drivers door switch now...
Good  luck,
Mick
23 minutes ago, stewart white said:
Hi thanks will give it a go thanks
It will work.
If you have a moon roof you may need to do the same with that.
go to passenger side wind window down hold down for a few seconds and do up ,repeat on rear windows ,hope this helps you
