Has anyone tried to clean streaks off the windscreen successfully?
I've had some success with Autoglym screen polish and Invisible glass spray. But I've got some mottling on the rear side windows that I can't seem to shift. Happy to hear others' ideas.
Try white vinegar or warm solution of bicarbonate of soda
Make sure the bicarb is fully dissolved.
Old valeting trick, clay bar works using water as lubricant, but 0000 grade steel wool is the "big guns". also prevents wiper squeak.
Use dry and be careful around trim.
(And do not use this method inside, exterior only folks).
Edited by Dragondrummer
