Hi. The yellow and green guidelines suddenly disappeared from my reversing camera (think I heard a beep before they did so) does anyone have an idea how I can get them back. Red line us still there. 2003 Alphard. Thanks
Were you fiddling with the head unit at the time, pressing buttons ! ?
Eightseater.blogspot.com has some info on the reversing camera and 'boxes'.
However, I don't think he covers recovery of the boxes.
Worth a read though
Hi
You may have caught the camera button on the steering wheel... try a long press to reset it. Otherwise it's deep in the settings menu...A press on the camera icon should get you in and you can change which lines you have..aided by Google translate!!
Hello
you can adjust it through the head unit from the G button options bottom left on head unit.
google translate is useful.
Sorry if repeating others reply
Thanks all for your help. PZ I think you might be right, as I said, I heard a beep as I started up and it was probably the camera button. Will give it a go. Thanks again
The camera button only operates the front camera the reverse camera is operated via the reverse gear switch for the reversing lights
