Engine management light
after driving for 30 minutes the engine warning light comes on in my 2004 2.4 Alphard, it goes out after the vehicle has cooled down.
I’ve tried to use my cheap OBD scanner to read the fault code and lay local garage couldn’t read it with theirs.
I’m thinking general air flow issue, oxygen sensor or Mass air flow sensor.
Has anybody experienced a similar issue?
Does anybody have any ideas, or know where I can get a relatively cheap OBD scanner to read the fault code?
thanks very much
Lee
  • 7 months later...
Hi Lee I have a similar problem that steady orange engine management light was intermittent and going on and off and now stays on until 30 mins driving then goes off i was also looking at a OBD scanner and found this review but havent bought one yet
Best OBD readers 2020 | Auto Express
can anyone tell e where the OBD port is on my 2003 3.0 V6 Alphard
Thanks John
Hi John, I was looking for the OBD11 port on my 2002 Alphard 3.0 and at first couldn't find it, even when I had been told where it was ! But now I do know where it is - if you put your hand under the plastic dash below the steering wheel - a little to the left of the steering wheel - it is just under the edge of the plastic lower panel - easier to feel than to see, but once you have got it - it is a white plastic socket, and then becomes easy to find again. regards, Graham.
I wouldn't spend more than necessary on an OBD reader. If you have an Android phone, get one of these for a few quid and the free 'Car Scanner' app from Play Store.
It helped me solve a number of problems on Jap import motors over the years, but crucially a mis-wired O2 sensor, knock sensor and MAP sensor issue on my 2002 Alphard.
Good luck, let us know how you get on.
https://www.ebay.co.uk/itm/ELM-327-Bluetooth-BT-OBD2-OBDII-Car-Diagnostic-Scanner-Code-Reader-Tool-Android-/383711223971?_trksid=p2349624.m46890.l49286
  • 5 months later...
I’m curious about this mis wired sensor. I put 1 on mine and fault still there?. Any info would be greatly received cheers.
Link doesn't seem to work.
I use the "Ancel jp700" jobd/obd2/eobd reader to get codes from my 2.4 2006
£50 on amazon
And yes..... the reader port is above the handbrake pedal, under the dash.
Currently getting eml and code p 0171 system too lean bank 1, gonna check vacuum hoses etc, maf, o² sensors.
Only get the light coming on after 30 mins of driving..... doesn't happen all the time !
Link does not work !
  • 4 months later...
Anyone know where to purchase a Bluetooth or WiFi obd2 jobd code reader
There are lots on ebay and Amazon. Make sure you get the software too !
