martin h Posted October 18, 2020 Posted October 18, 2020 hello just got my alphard yesterday 2006 mzg does anybody know how to play a dvd on the drop down screen please
Roland Posted October 23, 2020 Posted October 23, 2020 Hi Martin Use the button to open the screen you will then see two white arrow symbols which are normally associated with disc eject to the left of two slots one above the other The upper slot is for a CD put CD in the upper slot Close the screen and press CD button it will play to remove open screen and press the white eject button to the left of the CD slot it will eject the CD Hope this HelpsÂ
martin h Posted October 24, 2020 Author Posted October 24, 2020 thankyou Roland but i wanted to know how to play a dvd on the rear screen but i have since managed to find out how, thankyou anyway for replying to my question.
Guest Posted October 26, 2020 Posted October 26, 2020 Martin, how did you get a dvd to play, I've not tried yet, does it play region 2 ones do you know?
martin h Posted October 27, 2020 Author Posted October 27, 2020 to get a dvd to play on the rear screen when dvd is playing on front screen press the middle left hand button directly under the screen then press the top left japanese symbol on the screen itself and you should get a yellow line appear underneath, it should then be playing on the rear screen, when you turn car off and on again you will need to do this everytime unless anyone knows different, i dont believe it will play region 2 dvds as japan uses ntsc system hope this helps all the best martin.
Guest Posted October 28, 2020 Posted October 28, 2020 Thanks for the info Martin.  Top tip. If you have a smartphone use Google translate as you can point it in camera mode at the screen to get an instant translation 😉Â
