MK1 Face lift 2007 boot door unlocks itself WHILE MOVING!!!
My goodness! I have been hearing more noise from the rear of my Mk1 this week. Like a window was open, and a rattle. The rattle was really irritating me, so I sat in the back while my wife drove. To my horror, the rear door unlocked by itself! I have tried this in a few conditions now.
Static: I manually closed the rear door. Within 40 seconds it unlocked itself, to the point I could put my fingers behind the door and wobble. It appears to still be on the latch, but very concerning.
I then tried it electronically, which closed the boot, locked it. Then unlocked it and the boot moved slightly, again leaving finger space so I could wobble the boot door.
Slowly moving: both manually and electronically I closed the boot door. Jumped straight into the Alphard, Staithes engine and pulled off. I can get about 20 metres and the same result. The boot door unlocks.
Disabled electronically assist doors: manually closed and then Jumped in Alphard. Locked all doors with the lock button inside the drivers door.
I moved off, maybe drove 50 metres and the door unlocked itself again....
Any suggestions?
Cheers Dan
Any suggestions?
Cheers Dan
Hello Dan,
Do you have the Smart Lock System ?
On 3/20/2023 at 11:52 AM, Rojie said:
Hello Dan,
Hello Roger, nice to meet you!
I have no idea, could you let me know how I confirm that please?
Cheers Dan
Cheers Dan
You will have a separate fob for it. Just three buttons. Lock, unlock and tailgate.
The reason I ask is it can, when programmed through the head unit, perform all kinds of tricks with the locking system.
I was just wondering whether it has some bug or other malfunction; perhaps needing a new fob battery.
Doors can be programmed to lock after you drive off, etc.
Is your rear hatch electrically assisted?
On another line of thinking, I believe the rear hatch has obstruction detectors. perhaps there is a malfunction there.
I am just guessing, as no-one else (in my recollection) has reported such a situation  !
You have electric tailgate?
Do you have 'soft close' (where a motor pulls door tight if you don't close it fully?)
It sounds like the soft close motor is disengaging, maybe a loose connection, or debris in the latch mechanism?
My Softclose had a rattle, I took off the rear plastic trim, and 2 of the screws that hold the lock mechanism had worked their way completely loose!
This might be spot in then Roger. I do have that fob yes. We had a head unit fitted on the weekend (android upgrade) although the issue was happen beforehand, so I suspect this is unrelated.
It may be the fob, or as you say, sensors.
Fault finding action is required. I appreciate your response and suggestions 😊
Cheers Dan
This a a great idea 💡  ok, I will check that Chris!  Roger suggested a couple of potential investigations too. I will look at it this week and report back to the group.
Have a good day, Dan
Oddly after cleaning tge obstruction sensors the issue has not reoccurred. So, at the moment I belive it was exactly that.. dirty sensors??? Thank you all for your help and pointers, much appreciated 🙏
