My sliding doors have taken to stopping half way ever now and again. I'm thinking this needs a reset. Following a flat battery the windows were doing the same. I managed to reset them.
Any thoughts?
Any thoughts?
So, your sliding doors are electric ?
Is your once flat battery fully charged ?
Have you had it tested under load ?
Are the obstruction sensors clean ?
Battery is Def charged.
Where would I find the sensors?
Even if you open them manually? It must still think the windows in the doors are open.
I haven't tried manually actually. It's only intermittent on the auto.
There is a catch on the bottom hinge that activates if you open the sliding door when the window is open, I think it is a safety feature. Have a look next time it happens, if it is activated it works in both electric and manual mode.
  • 5 months later...
I’ve noticed the sliding doors only open half way when boots open
This is an odd point.
I agree that open windows will prevent (electronically) the door opening fully.
But I haven't come across the boot open issue before.
So I am assuming electric side doors (both ?), is your tail gate electrically assisted also ?
I’ve been told this is a safety feature.
and yes electric tailgate too
Hhmm, I don't think so.
I'll try it on mine and let you all know.
Yes. Just checked.
Both my electric side doors stop short of fully open when the windows are open.
This is as it should be.
My tailgate does not stop opening, or closing, whether the side windows/doors combination is open.
Does your tail gate operate perfectly when the side doors and windows are closed ?
