Anyone know what wires I need to tap into to get the front camera working, my Alphard had aftermarket head unit in and it was never wired up, I've replaced the head unit with a Android one that supports front camera just need to figure out the wiring for it now
Hello Tom,
Be cautious.
I'll think you will find your Alphie camera is 6 volts; whereas you new unit may well supply 12 volts.
You will need to check the wires at the socket for the existing camera you will also have to change the camera for a 12volt one
