8 hours ago, farooq said:
Hello, i have a alphard 2004, suddenly the odometer started blinking/flashing continuesly any help
Have attatched a video
Hello Farooq,
Close all the doors and buckle up the set belts !
Do the red lights go out ?
Brother is said the odometer is blinking not all the lights on the cluster and hve attatched a clip to show
The seat belt warning light is also flashing, so fasten seat belts start it up and try again if odometer still flashes then you could have a loose connection on the back or the ecu is faulty, has the speedo been checked for accuracy, when engine is running is it only the odometer that is flashing and does the eml go off
Came to there is a guy earlier did mileage correction on it since then it has been behaving that way
Mileage Correction ?
Do you mean converting from km/hr to mph ?
No reducing the km
54 minutes ago, farooq said:
No reducing the km
Reducing is clocking it's illegal
3 hours ago, farooq said:
No reducing the km
As defuzo says reducing the odometer reading is illegal here in the UK.
If the reading is now 375,000, I dread to think what it was.
I doubt our members will want to help.
I think you are on your own.
I certainly don't want to be involved; even if you are in a different country.
I would not be at all surprised if the blinking odometer is a result of tampering with the figure..... adjusting/resetting is illegal and probably why it started blinking after the alteration.
Thats what i think so is the culprit coz even checked with obd ther is no problem
Hi. Just a thought. Is it that it needs a service, or perhaps (?) In Japan, I've heard that at about 35,000 miles you are required to have an engine rebuild or replace the engine?
I can't confirm this is true, but have heard this from about 3 dealers!
John Harrison. Wallasey Wirral.
(2008 2.4 Vellfire)
(2008 2.4 Vellfire)
Na its not a must, but have checked its becoz of odo tempering which was done before coming to me, so am looking for original eprom dump so to fix it
Good luck. Can you post what you find?
John Harrison.
