Is there an OBD connector on the Alphard 2003? If so, where is it? I need to check out an engine warning light?
4 hours ago, Picasso said:
Just under the steering wheel lower down towards peddles
Thanks for that. Found it but unfortunately my cheap AutoLink device doesn't connect electronically. I have found posts on here describing difficulties finding a suitable scanner. As the warning light goes off after a while I'm going to assume it's just a non-serious sensor problem.
20 minutes ago, Picasso said:
if you had been nearer to Coventry could had read it for you
Thanks. If we are passing near there sometime I might ask if you are available.
yes that's not a problem on the 20th this month im going Southampton i pass oxford i will message you see if you want it still reading and if you do will meet up
What you need is a scanner with the JOBD proocol e.g. https://www.ebay.co.uk/itm/293956397780
OK. But I read an earlier thread where someone tried one of those - and several others - without success.
How sure can I be that it will work with our 2003 2.4L Alphard?
This one does work . https://www.ebay.co.uk/itm/155583959123
ANCEL JP700 JOBD OBD2 Japanese Car Scanner from Amazon worked on our 3.0l from 2006
