Philllx Posted June 2, 2023 Posted June 2, 2023 Vellfire 20 series 3.5 Just looking to upgrade my battery to a higher capacity, wondering what others are using, Tanya batteries recommended https://www.tayna.co.uk/car-batteries/yuasa/ybx5005/ Technology - Wet Capacity (C20) - 65 Ah CCA (EN) - 580 A Length - 232 mm Width - 175 mm Height inc. terms - 225 mm ------------------------------------- I currently have the yuasa ybx3005 Technology - Wet Capacity (C20) - 60 Ah CCA (EN) - 500 A Length - 232 mm Width - 175 mm Height inc. terms - 225 mm plenty of room in the tray seeing if there's anything bigger. Thanks
kully Posted June 3, 2023 Posted June 3, 2023 Please report back whatever happens, I have nothing useful to add other than I'll be purchasing off of what you find
Rojie Posted June 3, 2023 Posted June 3, 2023 On 6/2/2023 at 12:56 PM, Philllx said: Vellfire 20 series 3.5 Just looking to upgrade my battery to a higher capacity, wondering what others are using, Tanya batteries recommended https://www.tayna.co.uk/car-batteries/yuasa/ybx5005/ Technology - Wet Capacity (C20) - 65 Ah CCA (EN) - 580 A Length - 232 mm Width - 175 mm Height inc. terms - 225 mm ------------------------------------- I currently have the yuasa ybx3005 Technology - Wet Capacity (C20) - 60 Ah CCA (EN) - 500 A Length - 232 mm Width - 175 mm Height inc. terms - 225 mm plenty of room in the tray seeing if there's anything bigger. Thanks Measure the 'space' very carefully and give the dimensions to Tanya.
Philllx Posted November 16, 2023 Author Posted November 16, 2023 After a few months of thought bought the Bosch S4 E41, EFB 72ah, 760cca. Fits the battery tray nice. Thanks to all you guys as well from this post, very useful info.
