Hi guys, I had my cvt gearbox oil changed last year by a really good mechanic.
It was just a drain and fill so about 4 litres. Apparently after the refill you have to get the gearbox to temperature and once achieved (confirmed with a good diagnostic obd tool)
You then check the oil via the other nut which has the straw to adjust the level.
I was asked by a fellow Alphard owner what the temperature should be but unfortunately the mechanic has moved.
Does anyone know what it could be? I've checked YouTube where they mention getting the car to temperature but fail to mention what it is 🤦‍♂️
Hi Aftab, just checking if you managed to get the info? I am planning to change my hybrid gearbox fluid as well.
