Rear dash cam
Anyone fitted a rear dash cam? Did you route the cable above the roof lining?
If so how hard is it to drop the headlining enough to poke the cable down to the front?
Yes I fitted one from the front camera along the top wasn’t to bad used a trim removal tool then along where the plastic meets the soft material you have just enough leverage to poke the cable in have a look at the video I’ve posted.
hope this helps if it’s uploaded
Perfect, cheers Skippy. I would normally drop the headliner a touch and then I have a 10ft pokey stick that I would feed the wire down the car, but there is alot going on with our headliner, TV, vents, lights, I have twin sunroofs like you, didn't look fun to drop it!
