big_boz Posted December 12, 2023 Posted December 12, 2023 Anyone fitted a rear dash cam? Did you route the cable above the roof lining? If so how hard is it to drop the headlining enough to poke the cable down to the front?
skippy992 Posted December 13, 2023 Posted December 13, 2023 Yes I fitted one from the front camera along the top wasn’t to bad used a trim removal tool then along where the plastic meets the soft material you have just enough leverage to poke the cable in have a look at the video I’ve posted. hope this helps if it’s uploaded IMG_3726.mov IMG_3726.mov IMG_3726.mov IMG_3726.mov IMG_3726.mov IMG_3726.mov 1
big_boz Posted December 13, 2023 Author Posted December 13, 2023 Perfect, cheers Skippy. I would normally drop the headliner a touch and then I have a 10ft pokey stick that I would feed the wire down the car, but there is alot going on with our headliner, TV, vents, lights, I have twin sunroofs like you, didn't look fun to drop it!
