AH10 front door outer lower window rubbers
Hi guys,
Does anyone in the know, know what the part no's are for the front door outer window rubbers are (both sides)?
Mine have gone rock hard and curly at the ends and cause the windows to judder most of the time when opened or closed so want to replace them (assuming they are still available).
Thanks in advance!20231222_120309.thumb.jpg.58325cca4d1ce1711bdd8abb2ffaa35b.jpg
25 minutes ago, pipsyp said:
Hi guys,
Try toyota/alphard/epc.com to find the part numbers
Thanks Rojie, I looked but it's hard to tell from the diagrams what's what
LH: 6817258010
https://toyota.epc-data.com/alphard/anh10w/24294/body/6751/68172A/
RH: 6817158010
https://toyota.epc-data.com/alphard/anh10w/24294/body/6751/68171B/
I wonder if they've just become dislodged and need snapping back in?
Edited by Geralt
Found 2008 parts.
20 hours ago, Geralt said:
LH: 6817258010
RH: 6817158010
Those are the trims on the inside of the windows
Thanks all, just the weatherstrip that sits on the window has gone quite hard and curled up at the ends......probably beyond saving.  The rear ones aren't actually much better 😔
My mate looks after it and tends to have no trouble getting parts for it through the main dealer he uses so might be something I look at in the New Year.
On 12/23/2023 at 12:36 PM, dezufo said:
Thanks for this dezufo, I am going to get some of these in due course from Amayama as they aren't too expensive even with shipping.  Actually a brilliant little resource for sourcing parts.
I messed up one of my washer jets trying to adjust them at the weekend so I have ordered some replacements from these guys to test Amayama out!
