zaphodbb Posted Friday at 02:09 PM Posted Friday at 02:09 PM Hi Gerald, Best guess is neither of them - I think the two sockets on the top LH are the power in and speaker outputs, and both of those loom's you picture are for the 18 speaker / home theater equipped cars (but for different head units) which have different sockets and the MOST converter (the expensive box with the label) to interface the factory external audio amp. Are there any speakers in the headlining on your Vellfire? if not, I think you need this one: https://www.aliexpress.com/item/1005006851477450.html?spm=a2g0o.productlist.main.6.3f4148a51t2G3L&algo_pvid=cc97d0d8-8741-49ee-864f-85e1b2e982ac&algo_exp_id=cc97d0d8-8741-49ee-864f-85e1b2e982ac-5&pdp_ext_f={"order"%3A"33"%2C"eval"%3A"1"}&pdp_npi=4%40dis!GBP!3.59!3.59!!!33.41!33.41!%402103956b17467993634286885e316a!12000038516047136!sea!UK!2324886173!X&curPageLogUid=TtMaSPsYcBFr&utparam-url=scene%3Asearch|query_from%3A But unsure if you need the CANBUS adapter (small box) version or not. Maybe others can advise? 1
ged79uk Posted Friday at 02:30 PM Posted Friday at 02:30 PM no i think its the basic speaker set up, not seen any additional speakers on the dash or in the lining. from what i can see just 8 speakers. thanks for the link. will see what happens when the new unit arrives. at least those looms wont break the bank.
Sajeev Posted Sunday at 08:37 PM Posted Sunday at 08:37 PM (edited) Mod A for your unit. If you send the pictures of your old headunits rear ports to the supplier on Aliexpress, they advise you which one you require. Edited Sunday at 08:40 PM by Sajeev
