Anyone had it at all ? Pretty sure it's leaking from there
Very unusual for that to leak, most likely the plastic side tank on the radiator has a small crack, known fault due to age and heat, when rad is cold it leaks, when hot the plastic expands and it seals up, you can get replacement radiators off ebay that have metal side tanks
