Hi im new to toyota alphard and my vehicle is broken tapet sound and white smoke cmng and looking for a good garrage to fix around bedford area pls suggest many thanks
Hello Shan,
Are you sure it is a tappet ?
Not a blown head gasket ?
I  am trying to imagine how a broken tappet would produce the "white smoke".
White smoke is normally excessive steam due to a failed head gasket (or worse).
Check your oil cap for an emulsion with the engine not running.
Either way, you are still in need of a competent mechanic.
Any good mechanic around Bedfordshire
You can try search for ITS Autos Milton Keynes, they are Toyota specialist and can work on Alphard.
