Peterm69uk Posted June 1, 2024 Posted June 1, 2024 My auto headlights have stopped working, has anybody else had this problem and how did you rectify it ? cheers Pete
Rojie Posted June 1, 2024 Posted June 1, 2024 On 6/1/2024 at 5:40 PM, Peterm69uk said: My auto headlights have stopped working, has anybody else had this problem and how did you rectify it ? cheers Pete Expand Hello Pete, have you made any modifications to your machine recently ? Chris.ac is a whiz on most things electrical, and is located very close to you. He will probably respond to this quite quickly, but if not you could send him a Personal Message.
Alphard Club Posted June 1, 2024 Posted June 1, 2024 Silly question but i presume you have the lights switch on Auto? Sorry for asking Their is a sensor on the dash, is this covered? 1
Peterm69uk Posted June 1, 2024 Author Posted June 1, 2024 On 6/1/2024 at 7:00 PM, Alphard Club said: Silly question but i presume you have the lights switch on Auto? Sorry for asking Their is a sensor on the dash, is this covered? Expand Yes
Alphard Club Posted June 1, 2024 Posted June 1, 2024 On 6/1/2024 at 7:03 PM, Peterm69uk said: Yes Expand You may have accidentally turned off or lowered the auto lights setting in the infotainment system. Finding it maybe tricky, i use Google translate over the camera helps. 1
Peterm69uk Posted June 1, 2024 Author Posted June 1, 2024 On 6/1/2024 at 6:35 PM, Rojie said: Hello Pete, have you made any modifications to your machine recently ? Chris.ac is a whiz on most things electrical, and is located very close to you. He will probably respond to this quite quickly, but if not you could send him a Personal Message. Expand I fitted a dash cam, as stated on a previous post I was going to hardwire it by piggybacking a fuse with a kit I bought but in the end I just used a lead to connect to a usb for power. Where are the sensors located? are they the four blocks on top of the screen? if so the only thing I think I could of done is dislodge something while pushing the dash cam lead behind the linings? Pete
Peterm69uk Posted June 1, 2024 Author Posted June 1, 2024 On 6/1/2024 at 7:09 PM, Alphard Club said: You may have accidentally turned off or lowered the auto lights setting in the infotainment system. Finding it maybe tricky, i use Google translate over the camera helps. Expand I've got an Android system fitted and I've definitely not touched any of the settings.
Alphard Club Posted June 1, 2024 Posted June 1, 2024 On 6/1/2024 at 7:09 PM, Peterm69uk said: I fitted a dash cam, as stated on a previous post I was going to hardwire it by piggybacking a fuse with a kit I bought but in the end I just used a lead to connect to a usb for power. Where are the sensors located? are they the four blocks on top of the screen? if so the only thing I think I could of done is dislodge something while pushing the dash cam lead behind the linings? Pete Expand sensors are on top of the dash itself, either the black dome or the silver sensor, i forget which one. Top Windscreen sensor is for Autowipe wipers 1
Peterm69uk Posted June 1, 2024 Author Posted June 1, 2024 On 6/1/2024 at 7:11 PM, Alphard Club said: sensors are on top of the dash itself, either the black dome or the silver sensor, i forget which one. Top Windscreen sensor is for Autowipe wipers Expand π I recently bought a dash mat, thought the dome thing was a GPS, I'll go test it now with the mat ππ»
Rojie Posted June 1, 2024 Posted June 1, 2024 On 6/1/2024 at 7:16 PM, Peterm69uk said: π I recently bought a dash mat, thought the dome thing was a GPS, I'll go test it now with the mat ππ» Expand I have a dash mat. Carefully located they will not obscure the light sensor. 1
Peterm69uk Posted June 1, 2024 Author Posted June 1, 2024 Thanks everyone, yep the front dash mat was covering the sensor, getting to learn what all these bits and pieces do on the car with the help from this forum π Pete
