Hi, I’ve recently imported a 2010 vellfire, however there is a slight knocking sound when travelling over small bumps at lower speeds (sub 20miles, more pronounced when going over bumps on the driver side), it sounds as though it is coming from the upper steering column. It doesn’t affect the steering of the car in anyway simply just makes a noise.
I’ve already replaced the steering damper bush (although the original one was in good condition) as well as the driver side ball joint due to a tear.
Any help would be greatly appreciated in diagnosing this (based in York)
Yeah that was all done in Japan pre-import alongside swaybar bushes, as the car was previously a VIP build over there on coilovers and wider alloys. My best guess is that the extra stress from the stiffer suspension must’ve worn out the bushes in the upper part of the steering column , but can’t seem to find much info on replacing it.
Would it be easier to just have the upper steering assembly replaced or would you be able to recommend a specialist nearby.
It’s a ANH20 model but we’ve yet to register it in the UK
EDIT: double post.
Edited by Jimmympv
On 6/24/2024 at 4:41 PM, Picasso said:
bottom steering colum joint known fault on these if you pm me your reg no. i will get the part no. for you and might beable to point you in right direction to get one
Sorry to bump this thread but I’ve just collected my 2012 Alphard and I think it has this exact problem. Would i be able to get the part number please?
Always check the steering damper first as it's the cheapest part to replace. I had my steering rack replaced, luckily under warranty but it ended up being the damper.
Hi i am Amina I have modle toyota vellfire 2011 I have problem In speed it's goes 60mph I goes too motorway my car speed struggle too go up 70mph and engine sound like heavy pressure and I took it in the gearge too repair it they told speed sensor gone I told them replace it new one after 3day later still got problem with the speed after I took it too the gearge they told me do service I did service 3 time I spent £500 pounds and still speed  problem if anyone can advise me what to do how too solve the issue with speed goes down automatically??
