Good day all ,
does anyone know the procedure to reset the keyfob and smartlock central locking feature ?
My smartlock fob and one of my keyfobs have just stopped operating the locking system  , although
the keyfob still starts the vehicle .
Any info. gratefully received .
Thanks,
Roger B.
8 hours ago, roger b said:
Good day all ,
Thanks,
Roger B.
Hello Roger,
I would start by renewing the battery in the Smart Fob (which won't start the van).
A dud battery in the ignition fob will not prevent the vehicle starting, but will affect the locks.
If a new battery is ineffective, you may need to get the key reprogrammed.
Imho, a auto locksmith is the way to go, but I have seen a process on this Forum, possibly with mixed results
Change them one at a time, not together to minimise mishaps.
Thanks , I'll give it  a try although the smartlock fob battery is good.
The issue has appeared just after having a new keyfob(which works fine) cut and programmed ???
Coincidence????
