Leisure battery location.
Where have you all mounted your leisure batteries?
Nearside rear wheel well.
I have a rear conversion; so the leisure battery is located under the nearside dining bench seat.
Thanks, I'm doing a rear conversion as well. I'll be using a voltage relay switch. How have you routed the connection to the main battery?
I didn't perform the conversion.
I suspect the live route was along the nearside under the carpet and insulation.
I have a split charging relay in the same location, adjacent to the leisure battery.
I also have an EHU and the isolators are in the cupboard at the rear.
The EHU enters under the floor at the left rear, very stealthy.
Thanks for the information.
