Dear All,
I have just taken possession a 2006 in white!
I have noticed a wobble in the steering wheel which conicides with a squeak from the front brakes.  From this I am assuming the rotors are baked and warped. (Had tyre and wheel balance checked - all good)
after looking online I have found the front disc to be 275mm and the rears 296mm
is this right???? Rear discs bigger than front???
oh any recommends for make and manufacturer of discs and pads
On 9/4/2024 at 1:22 PM, Swinborg said:
Dear All,
Hello Max,
Send a PM to Picasso with your VIN number.
He will supply the part numbers.
for my MNH15W Front brakes are shared across MANY toyota vehicles of the same vintage.  rear brakes are not; only shared with toyota sienna (north american mini van).
Use this resource to match your vehicle and find your exact part number; u can likely buy it locally.
https://jp-carparts.com/toyota/cartypelist.php?maker=toyota&type=713120
