12 Volt Electric heaters
Anyone know a good 12 volt electric heater to connect to a 2nd leisure battery?
You will quickly drain a battery with a heater. For example, if we assume it was possible to extract all the energy out of a 100ah battery, it only holds 1.2kWh of energy. It isn't actually possible to totally drain a lead acid battery of all its energy without turning it into a door stop, so it would be far less than this. You might be lucky to get half of that it you don't want to wreck your battery.
