Mirror led indicator lights not working
Hi everyone,
On my toyota vellfire 2014 the mirror led indicator light are not working, what can be?
Thank you
The fuses are ok, someone told that if was the fuse all the indicator lights wouldn't work, so I don't know
Check for loose connections in the housing, and/or suspect wire chafing.
I retracted my mirrors a few times and hey presto.
I do not normally retract mirrors for every parking ocassion.
you can get replacements pretty cheap on AliExpress. I got a set of sequential ones for about £20.
Get hold of a plastic pry tool, you need to tilt the glass down and pry it off, if you have the heated mirrors be careful as they will be wired in so don’t want to break them.
There are a few clips holding the casing on, pop them out and run the pry tool along the opening to pop it off.
there should be two screws holding the light in place. You can just unplug it and plug the new one straight in.
I guess you could also pop the working one you have in to see if that works on the other side.
