Hi, is someone can help me finding a way to get/order a replacement key for my Toyota Alphard 2005
Thanks in advance
Welcome if you pm me your vin chassis no. i will be able to give you part no. for the key and point you in right direction to buy one please bear in mind the key has a transponer chip in the key and will need programing to start the engine as it has a factory fitted imobilzer fitted
Hi Lee, can you please help me with my request: my vin chassis is: MNH15-0034179
thanks for your help in this matter.
JP
JP
The keys are available on ebay UK, and are quite inexpensive, programming them is not cheap; 80 to 100 GBP.
As Lee says you will need the key blank with the correct chip.
Your model year falls in a changeover year as a Gen 1 or Gen 1 facelift.
Unfortunately, the key chip is different in the two model incarnations.
Lee should be able to identify exactly which one you need.
My guess is 4D67, but wait for Lee's answer.
Hi Lee and Roger,  thanks again for your helpful information, I will order the key per your comments.
I appreciate very much this forum with Alphard owners.
JP
Hi Picasso, I'm a new owner (2005 Hybrid) and also would like a 2nd key. Where do I find the VIN chassis number please?
Hi Picasso, many thanks, my Reg no is below:
Toyota (hybrid) Alphard 2.4L
Reg. OW55ENA
On 1/18/2025 at 8:08 AM, Picasso said:
Welcome vinny the vin no. Can also be found just inside the pillar drivers side door where it locks shut
Hi Picasso is this the VIN "ATH10-0013686?" see picture attached. Ps is the VIN "0013686" as I need the VIN for a fault check on an OBD reader. Cheers.
Edited by Vmhan
Request confirmation of VIN.
4 hours ago, Picasso said:
hi your oe no. for the key is  8978660170  and the link for buying it   https://partsouq.com/en/shop/shoppingCart/view  i buy all my genuine toyota parts from here lot cheaper than uk toyota please remember this will need to cuting and programing to the vehicle
Hi Picasso, many thanks for the info, I've ordered the part as advised. 👌
Edited by Vmhan
