Hi. We’ve got a 2007 2.4 Alphard. The battery needs replacing. Currently Bosch S4 020. 330 CCA.
Do I need a battery with a bigger CCA? Any recommendations for a suitable replacement? The clamp width appears fixed at about 230 mm. not sure how to attach a wider battery.
Any suggestions gratefully received.
cheers
Kim & Kev.
cheers
Kim & Kev.
I suggest you contact Tanya Batteries.
They provide an excellent, and safe, mail order service.
Assuming your bracket has not been modified they will be able to supply the 'correct' battery, at a very effective price.
Batteries with higher CCA are not necessarily any larger, but care is needed.
Mine, a Yuasa, was easy to fit; but you will almost certainly need to reset the windows, and maybe the moonroof too.
Both an easy process (assuming they work correctly)
There is always Halfords, or Kwik Fit who can/will test your current battery first (without obligation).
Thanks Rojie.
