59 minutes ago, Stewart whitton said:
Is there a way to make these buttons work again after a campervan conversion
Hello Stewart,
Rather a vague question, don't you think ?
Which buttons ?
If it was a commercial conversion, take it back and have the supplier fix it.
(Conversions don't normally involve the steering area, unless your rear fog light feed has been has be taken from there).
If it was a home conversion, only you will know what has be touched / attempted.
More information, please.
Can you also please advise whether you have a 02-08, a Gen 1, or a 08-15, a Gen 2, as in your topic header.
It was a proff company who did the conversion. I will ask them, thanks
Hello Stewart if you got newer model 2010 your profile shows earlier model your going to get the wrong help from members please change your profile to correct vehicle
Presumably you mean for the stereo? Is so, there are converter boxes that take the signal from the switches and convert it to what the stereo needs. You would have to find one that works with your vehicle and your stereo, but it is normally straight forward enough to find one that is compatible.
I'm guessing that the conversion involved removing the Jap radio with limited band width and fitting one with fall FM band width and a reverse camera. What you will find is that you need to look at the back of the radio itself.Modern ones have  plug in wiring that runs to the wheel controls. Others will need a kit. to work.
