Hi everyone I need help my passenger sliding door got stuck in managed to close it but now open a little bit then close and making grinding noise.
Check to see what it is and noticed the cable the sit under the window on outside is splitting.
How do u change that and is it hard and where do u get parts from.
Could anyone help please
The main problem is that the cable frays inside the door as well and fouls the mechanism, there are 2 solutions, 1) change the cable/mechanism inside the door which entails removing the door card to get at the part, 2) cut the cable as close to the door as possible, switch off the power door on the dash, then you can open/close the door manually. Part available on eBay > https://www.ebay.co.uk/itm/176509903974
Hi, A few months ago someone was trying to be helpful and tried to force the sliding door shut. I managed to close the door to get home. Had a real problem re-opening the door. When eventually opened, the operating cable had "jumped" the pulleys and damaged the whole mechanism and cable. We made the decision not to spend hours of time and large expense to replace all the components,so I removed all the mechanism and cables and we now have a manual sliding door,which to be honest is no problem to use.
  • 4 months later...
have you done this on both doors?  I have one where the cable is fraying and was thinking of just cutting that cable, but I assume the door mechanism would still try and work if the handle was pulled?
Hi, I only removed the cable from the Left hand door.The mechanism still completes the un-locking cycle,then the door can be opened manually. Hope this helps.
