My automatic sliding door on my alphard wont seal shut, it closes automatically and manually but the final bit where the door is pulled in isn’t working. I can see and hear it being pulled in and closing but then it’s released and isn’t properly sealed. Any help?
Hello Chrissie,
Try searching the forum.
Door closure problems are not unheard of.
Look in the technical section.
I had the same issue on both my side doors.mine was the catch at the back of the sliding doors wasn’t working right as the cable to it had stretch a little.i adjusted the cable where it goes on to the lock and it worked fine.i don’t have any pictures to show you.it wasn’t one of my favorite jobs but i have done both doors.same problem.hope this helps a little.could probably explain a little better but its late and tired.good luck
