Running on empty!
Great song, but I digress already!
Had the new to me experience yesterday of bringing up the low fuel light. I blame the incident on me not having had a decent drive in the old bus due to other issues.
Off I went with my £20 voucher for butcher meat from a known good butcher in the wilds of West Stirlingshire.
After a few miles I realised tank was rather low but I knew where the only station for miles was so pressed on. Imagine my delight to find it closed for major refurb.
I'm 13 miles from my nearest station so a very light footed journey commenced. 10 miles later low fuel light comes on, totally new experience for me in van.
So, I make it to station & she takes 61 ltrs, another 1st, but having now found out tank capacity is 70 ltrs I am brimming with knowledge.
Not that I’m going to make it a habit but I reckon a 2.4 petrol should give you 40-50 miles after low fuel lamp comes on.
25% on the gauge is going to be my fill up criteria in future 😂
The last time I experienced the squeaky b*m feeling was when the sun shining over my shoulder onto my m/ bike digital gauge hid the fact that it was flashing a low fuel warning. Passing through some shade & noticing it caused major alert. I was halfway between supplies, Inveraray to Arrochar.
Press on or turn back?
Onward, commanded the steed!
Roads normally ridden at enthusiastic speeds became even more scenic.
Arrochar reached & all was well.
Inverary no longer has fuel station, nearest would be Loch Gilphead.
I have a 2.4 AH20 VELLFIRE. Normally I fill up at about 1/2 full as if you run it right down you are likely to pick up sediment from the tank bottom.
I did actually run mine down last week. As I opened the filler, it gave a massive sigh!
Used to gave that on one of my Chevettes years ago and someone told me to drill a 1/6th inch hole in the cap. I did and it seemed to run better!
Sometimes before filling up it does seem to miss a beat or have a little wobble on occasion. Has the tank got a breather and, if so, could it be blocked???
John Harrison. Wallasey
PS. I really love my Vellfire; 3 years now and just passed another MOT. GREAT!!!
Oh wow...so the Londis place under the arch no longer supplies petrol.....that's a pity
Not for a long time Alasdair, Arrochar unmanned is nearest.
Londis was cheap too 😢
