Hi I have a pending code on my 2008 Alphard 3.00 V6 I have changed the front oxygen sensor twice but it still shows a pending code & the engine management light still comes on. Anybody got a solution please. Jon
Hello Jon,
I expect Picasso will help you on this.
P0135 Powertrain O2 Heater Circuit (Bank 1 Sensor 1)
Hi Jon,
Been there. Replace the other O2 sensor that sits under the car and sees water, salt and elements more often. From the other bank.
Cheers
Lukas
Thank you - are the 2 sensors the same?
Many Thanks
Thank you Guys sensor under car replaced all ok.
