Reattaching body kit/ side trims on an alphard
Hi can anyone tell me how the body kit skirtings are fixed to the doors of a 2003 Alphard? Drivers side one on the bottom of the door is coming loose and I’d like to tighten it up so it doesn’t waggle around. Thanks 😊
Hi. I have a 2008 AH20 Vellfire and last year I clipped one of those high angled kerbs in a Motorway Services; right down one side.
I managed though a main Toyota Dealer to get the correct clips and thd correct diagram to show where the clips go!
The only downside was that a bag of clips was around £50!!!
The good nes is that all yhe side trim is on as it should be!!!
I'm not sure about the AH10 model but it is worth an ask at the dealer first?
Good luck
John Harrison. WALLASEY.
There are 2 types of clips, the ones at the top push into holes on the trim then slide down onto a retainer on the door, the ones at the bottom fit into square slots on the trim then push into holes in the door.  Both types are available on eBay; Top clips number 196877085828. Bottom clips number 384266009852. I have seen posts where people have used Sikaflex adhesive to hold the trims on
