Hi all. I noticed a car I was looking at has premium speaker system I think it is. What specific leads and head unit would be required. So I don't lose any functionality of speakers and rear camera ETc? Thanks
Hi G,
I don't understand your question.
Are you considering changing your head unit and asking for recommendations ?
40 minutes ago, Rojie said:
Hi G,
Hi rojie. Apologies. I've currently found a vellfire that has the premium sound I think it's called. I wanted to change the head unit so I can use maps and English working radio etc. Was wondering if someone has done it to this set up instead of the standard audio system.
1 minute ago, glarhzilla said:
Hi Rojie. Apologies. I've currently found a vellfire that has the premium sound I think it's called. I wanted to change the head unit so I can use maps and English working radio etc. Was wondering if someone has done it to this set up instead of the standard audio system.
Firstly G,
If you are looking at a Vellfire, you vehicle profile is incorrect.
A 2008nVellfire will be a Gen 2 machine, 2008 onward.
Your question is a very common question, with hundreds, if not more, responses on this Forum.
You should search for Head Unit (or similar) and/or Android (or similar) in the search box at the top rhs of your home screen.
Be cautious, as some of these upgrades are far from simple, especially with the multi-speaker systems.
A photo of your current head unit may help members help you.
