I lost my near side passenger door moulding whilst driving! I will also require some clips. Can anyone recommend a supplier for a replacement.
May have to get it resprayed if colour match unavailable (Silver 1E4).
Many thanks in advance.
2007 2.4lt. silver Alphard HS07 GNP.
Front. Found a black one on ebay, but can hold out for a colour match if I have to.
Hi lee, Many thanks for info. Great that it's colour coded & clips are supplied. Just ordered one.
Hi again Lee,
I have received the below email from Amayama. When I made the order I asked for it to be colour coded & include all of the fixings !!
I've tried in vain to navigate through their ordering system!!
Sorry to be a pain, but could you please send me another order layout as previous to include all of the fixings that I'll need.
76914 (LH) Colour code silver 1E4
Clips top of panel  75397-58010 x 5
Clips bottom of panel 76933 x 4
The bolt on top right looks ok
As the whole moulding was ripped off, It looks like I will also require the bar - part 76926D. What do you think ?
Email from Amayama - Please reconfirm the exact parts required via the diagram, including any smaller parts which may not be included in the main assembly:
https://www.amayama.com/en/genuine-catalogs/epc/toyota-japan/alphard/anh10w/36857?frame_no=ANH10-0174048
Clicking on the factory code in the diagram will provide the full part number (and a link for the part number page where it may be added to your cart).
hello james always use fedex as the courier as 99% of the time you wont get hit with custom charges i have ordered from these about 10 times and never once been hit with charges using fedex
What Lee says is true for low value items.
I import from Germany using Fedex and can assure you that Fedex is extremely efficient at collecting duties and VAT, when appropriate.
Just keep your purchase value as low as you can.
The duty and VAT thresholds are explained on the HMRC website.
17 hours ago, Picasso said:
hi james im more than happy to help you check this link https://www.amayama.com/en/genuine-catalogs/epc/toyota-japan/alphard/anh10w/36857/body/7652?frame_no=ANH10-0174048  then open the basket you will see befor opening the basket its your colour code in title also this is for everything you need including the clips
Thanks, I'll try again. .
Thanks Lee, managed to complete order, BUT they're quoting delivery 10 October - 5 December !!
For used parts you could also try https://autoparts.beforward.jp/
Shipping costs can vary wildly though, but I've found stuff there I couldn't find anywhere else. It's also worth calling around breakers yards, lot's of leg work but can find stuff that isn't listed online.
