Found a garage in Nairn for Toyota Alphard
After being told by my garage that I had to find the parts to fix my van.  Apparently easy to find on Bay!!!!!  Not ones to fit my van.  Eventually after being told by Toyota in Inverness that they don't do imports, I was told to go to Bitz garage in Nairn.  They keep Alphard parts and were able to source the parts for my van.  Although an expensive trip for me as I had to find accommodation while I waited, it was worth it.  I will make sure I book in with them when necessary when I come on to the mainland.
Also found a great auto electrician on Isle of Lewis who fixed the sliding door on my van - needed a new cable.  He also supplied a better leisure battery for me.  Jim Brown at Motoplus.
Bush pins for rear axle.
 @Carodragon We have a member here called @Picasso (Lee) who might of found these parts for you. if you are ever looking for anything give lee a shout who can get the part numbers for you.
You can cross reference these numbers. A lot of parts are interchangeable with other toyota models
You can cross reference these numbers. A lot of parts are interchangeable with other Toyota models
Lee, in the main, will also advise when to go with OEM parts and when economies can be made with factor parts.
