Hi everyone, I have recently imported an Alphard Hybrid 2362cc 2014 model.
Unfortunately the battery is dead and it has a pressure sensor and an exhaust connector.  I need to replace the battery.  Can someone guide me where can I get this battery from as I have tried to find it and no one seems to have it.  Also, can I replace it with a normal 12v 43ah battery as these are the specs of the current battery.  If so what do I do about the pressure sensor and exhaust connector?
I have attached some photos that might help.  thank you so much for your help
Edited by Dean123
improved description
Welcome Nadim pm me your reg no. I help lots of members on here with part no.s will point you in right direction to get battery from you need to replace with correct battery you already noticed you got the heat sensor on the battery
Thank you so much for your message.  I just sent you a pm with info.
55 minutes ago, Picasso said:
Nadim the oe no. for the battery is have a look on ebay or got toy your local toyota
  28800-31291
Thank you so much.  Is the the ebay item number?  When I put it in eBay it brings a list of different batteries.  The one appearing on the top says its compatible with Lexus only.
Edited by Dean123
thats the listing but the listing also says give them your vin no. so they can check the batterys fit more than one vehicle lexus parts share same parts as toyota on the alphards
Yes.  The seller just messaged me back saying my battery is on a back order.  Thanks for putting me on the right path.  Hopefully it will get me sorted soon.
Mines also a 2014 hybrid - the previous owner changed the battery for a generic non AGM 12v battery, with no temperature sensor connected. As that battery started to fail it caused warnings about the Hybrid battery needing to be replaced etc. Since changing that out for an OEM S55D23L, everything is fine again - no more warnings. That was a couple of months ago.
Just replaced mine (2014 Hybrid) as it had dropped to 10.8V - bought from Tayna Batteries (Yuasa S55D23L) BUT via thier eBay store as it was cheaper by over £40 due to the eBay discount code, so 'only' £242....
I can confirm it is exactly the same as one that came out (same brand as well) - tried to recondition the old one but although it 'fully charged' according to my C-Tec charger, once disconnected it reverted to 10.8V.
Beware of some of the eBay sellers as they have NOS - saw one advert for the Panasonic version but with a date code of 2021 - the Yuasa I bought from Tayna was made mid 2025
10.8v is an indication that one cell is down.
I had this with a Yuasa battery from Tayna, within guarantee.
They replaced it foc.
