Can anyone identify this power cable
This came with the attached device in the car, I want to identity the power cable so I can buy an adapter for the said cable to convert to usbc.
any ideas what its is:
I know its not micro usb or mini usb..
thank you !
its a micro USB plug shape although cant really judge the size. Depending on what it connected to, it probably has the same pins inside, but sometimes they change the size so you have to use there cables and accessories. A bit like Apple with the lightning connector, before they finally used USBC like the rest of the world
Why do you need to know?
Edited by Voodoo101
