MOT failure on emissions
Hi All. Just been advised my 2003 Alphie failed MOT on exhaust emissions. Garage advised I can try have more repairs done but if still failed for emissions it might need a catalytic converter. Does anyone have an idea on cost and even part number for such? Thanks
Hello Ian I help lots of members on here with part no.s can you pm me your reg no. also may I ask what you have already tried to bring your emissions down
Cat part number is; 25051-28170, see link; but you could try some catalytic cleaner first to see if that improves the emissions https://www.amayama.com/en/genuine-catalogs/epc/toyota-japan/alphard/ANH10W/35720/engine/1701
Thank you so much for that info Dezufo, much appreciated. Tbh I kind of expected some work might be needed as van is quite old now but still in v good condition. New catalytic converter going in tomorrow with lamda sensor being cleaned at same time. Hopefully after that it will pass MOT. I'll lyk :) thanks again
Thanks to those that reached out. Pleased to say after new cat fitted along with some minor pipework changed van is now good to go. Cheers :)
