Unlocking doors with fob issue
Hi All,
Recently my 2010 350X will lock with the key fob, however when I try to unlock, it emits three beeps and the indicator lights flash three times, but it will not unlock.
I have to manually open the driver's side with the key then unlock each door manually.
When the ignition is on, the unlock bottom on drivers side will not do anything.
The car does lock with the fob. The tailgate also opens as well, but none of the other doors will.
I have recently got a new car battery, and changed the key fob batteries. Anyone have any other ideas of what to test?
Hi @Curiousgeorge
that sounds like a really annoying problem to have! It's a bit of a head-scratcher when one part works and the other doesn't.
Chris.ac makes a good point about the driver's door control.
If that's only locking and not unlocking from the inside, it might point to something a bit more complex like the ECU, as they mentioned.
Worth checking that first to see if it behaves differently. Fingers crossed you get it sorted soon!
Cheers Tango
Three beeps and three flashes on these usually means the car thinks a door is still open or it is seeing a fault in the unlock circuit, so it refuses the command. The fact it will lock from the fob but not unlock from the fob or the drivers switch (with ignition on) is a good clue that the unlock side of the system is what is failing rather than the key. A couple of quick checks that narrow it down fast
When you unlock manually with the key, do any of the other doors try to unlock on their own, or is everything completely dead and you have to do them one by one
Does the dash show any door ajar warning when all doors are shut, including the tailgate.
If you press unlock on the drivers switch with the ignition on, can you hear any faint click from the dash area or door, or absolutely nothing Common causes on 20 series Alphard Vellfire Door lock actuator failure can stop that door responding, but it would not normally stop the drivers switch unlocking all doors. Still worth checking if one door is reporting ajar, as the car can behave oddly if it thinks a door is open. Body ECU or its unlock driver is failing. People often describe it as the relays sticking, but it is effectively the unlock output stage not driving the actuators properly. That matches lock working but unlock not from anywhere. Practical next step if you have access to Techstream or a decent scan tool Check the Body ECU for DTCs and live data for each door courtesy switch.
If one door is showing open when it is shut, fix that first. If all door status looks correct and there are codes relating to door lock motor or unlock circuit, that points more to wiring or the Body ECU output. Also worth a basic electrical check Confirm the drivers door switch connector is seated and the wiring in the hinge area is not cracked. A broken unlock wire in the door jamb can kill the switch function, but it would not usually stop the fob unlock too, which is why I am leaning ECU output or a system wide inhibit from a door ajar signal. If you can answer the three questions above, especially whether any door ajar is showing and whether there is any sound when pressing unlock on the switch, it will help the group pin it down quickly.
Hope it works out! )
Hi All,
Thank you so much for all your ideas and feedback.
Gemini was a peach in helping diagnose the problem. Some guys in Birmingham that I spoke to also pointed me in the same direction.
The answer was a failing solid state relay. So the passenger side assembly relay ( the box with the fuses underneath it) was the culprit. At one point I thought it was impossible to unplug the original unit and almost gave up. The system was registering key fob signal, however wasn't doing anything. The dead drivers door unlock switch was a sign of the unlock system issue rather than a dead motor in the actuator. One door that is separate from the rest is the tailgate. That would unlock if tried opening the door. Symptoms of the issue are intermittent unlock issues. That means the relay is starting to stick and will fail. Mine was showing symptoms for a few months before complete fail. Like an ostrich, I buried my head in the sand and hoped it will just go away.
But before I bought the assembly relay, I did change the actuator motor in the driver's side door. I also learned that I won't take anything like that apart again without something filming the process. So much swearing... If budget allows just buy a whole unit. It's not designed to be decompiled.
Anyways, passed my MOT for another year. The Alphard continues to ferry our family of 6 with it's sleeper 3.5L
Love the roar, love tyre squeal. Love that car.
Glad you got it fixed.
The relay box is an absolute bugger to get out, but the solid state relay was the problem for me, too.
I can understand that they form part of the security system, but Toyota could have made these more accessible.
