C1310 hv solenoid booster fault, 3 lights on dash, engine cuts out sometimes
Hello fellow alphard lovers!
Got my 2.4 efour hybrid 2006 for about 3 years now, absolutely love it and have done about 30k miles on it, absolute joy!
Until last week, unfortunately..
First of all the car wouldn't switch on, funny noise (not funny actually), no idea what it was seemed like there was something jammed or rattling? Noticed oil level was low (as usual as been told the 2.4 engine between 2002 and 2007 have a piston ring issue? Correct me if I'm wrong), topped up the oil, connected my battery booster and it finally fired up with a nasty surprise, 3 lights on dash (as per picture)..
Since then the engine has cut off twice, once because hybrid battery went so low the engine cut off and wouldn't switch on, had to call AA who cleared the codes and it switched back on, second time was on motorway, it switched off for no apparent reason, stopped on hard shoulder, waited couple of minutes and it fired back on...
Apart from all listed above, noticed the engine doesn't seem to stop when hybrid battery is fully charged (it used to), the usual start stop waiting for traffic lights does not happen anymore, and the usual hybrid ecu that shoes battery being charged doesn't show the usual yellow and blue arrows, apart from other minor things that came along like: can only open driver window the other ones stopped working, cruise control doesn't work and the 100v ac power (used to use it to charge my phone) also doesn't switch on anymore... Worth mentioning that couple of weeks ago I had none of these problems, apart from constant oil top up (5 to 10l a year)
have taken the car to 3 different garages, all of which have different views of what could be wrong with it (first one doesn't know what's wrong, second said it's probably the inverter and the third says it's probably hybrid battery)
Any ideas or direction would be extremely welcome!
Many thanks
Gabriel
Hello Gabs,
So sorry to hear of the issues with your Alphie.
The only sensible suggestion I have is to take it to a Toyota dealer.
They must have experience with the Toyota Hybrid system.
I know some are huffy about working on grey imports; but they are not all like that.
There must be some helpful Toyota dealers near your location.
6 minutes ago, Rojie said:
Hello Gabs,
Hello Rojie :)
Real bummer as I absolutely love my alphie, but as I use it for work been really stressed lately, afraid it might let me down any time..
I've called the Toyota mainline and they wouldn't book me in because it's a import, should I just drive in and try my luck that way?
Both my local Toyota "specialist" and the AA couldn't really get hold of the codes, would you suggest a code reader that actually works with the alphie boy?
Thanks for your time mate
I don't have a hybrid and I can't suggest a suitable code reader.
Cuttothechase on youtube, Ldrego in the Forum has a video where he is using an OBD machine.
Drop him a PM he may be able to help suggesting which unit he has.
I found it very interesting that low type pressure can trigger the VSC warning light.
If there is an ABS fault (I'm not suggesting there is) the VSC will not operate.
VSC will not operate under 1 5kph anyway.
There is a note in my handbook (not in the Hybrid section) that states "When starting the engine or moving immediately after the engine has been started, a noise can be heard from the engine bay. This is simply the sound of an (VSC?) operation check and not a fault"
My handbook also states "the condition of tyres can influence the (VSC) system greatly so check the tyres carefully".
(Not explicitly stated but I assume this refers to tyre pressures too).
Isn't the right most yellow light the footbrake tell tale.
As your vehicle appears stationary I would expect that light to be on !
Cheers bud, just dropped him a message about the obd..
In regards to the footbrake my light is red and on the left side of the dash, didn't include that in my shot.. those 3 lights are on all the time whilst I'm driving..
And the noise coming from the engine bay was a different noise, rather loud and rattling whilst I was trying to fire up the engine.. that didn't happen anymore, it was just the start of my problems!
I know the noise you mean from the book, it's rather low and "electronic like".. not related to it..
Thanks for your help mate, any ideas are greatly appreciated! Gonna go through all my fuses today to see if I find something there.. you never know
That yellow lights seems to be a Brake warning light. ( ! )
Probably not the ABS though as that warning has a slightly different symbol (ABS)
OK, there is some software called Techstream.
Some say it's a free download; I believe you can rent it, daily, weekly, etc.
Search for Toyota Techstream. It is the official diagnostic tool (but may not cover Alphies). I expect most codes are similar.
So we got brake lights, vehicle stability control and that red car is hybrid system light right?
I've just ordered a code reader (Ancel JP700) apparently specifically for Japanese cars, will post here how it goes.. Fingers crossed
Isn't the techstream what my garage probably used?
If the code reader I bought doesn't work will try that! Thanks Rojie
If your local garage is an official Toyota dealer, it could well be.
There are other forum members who are more informed than I am on Techstream.
Chris.ac is very technically capable, and, I think, is, or has been. a Techstream user.
Hi got similar problem, same warning lights come on +4wd. When get the car battery was completely dead, charged the battery and stationary all looks like should- car starts no warning lights hybrid system works with all the charging arrows on the screen. Just when the car reach about 10mph ,after we gearbox kick all warning lights appear. After hours spend on research got some hints:
looks like toyota are sensitive for low battery voltage and need reset of few components:
1 . power windows - done
2 .check tyres pressure 35psi front and rear - done
3 .angle sensor - will try in next few days
Manage to check fault codes by AUTEL MAXI DIAG MD808 pro
my codes:
P3125 INVERTER MALFUNCTION
C1259 HV SYSTEM REGENERATIVE MALFUNCTION
C1310 HV SYSTEM MALFUNCTION
C1253 HYDRO-BOOSTER PUMP MOTOR RELAY - that one possibly create the problem because VSC FAULT AUTOMATICALY DISABLE HV SYSTEM, but first will try reset angle sensor (angle sensor is crucial component of VSC system and on live checks when engine running angle sensor value not react on steering wheel movement)
alphard hybrid 2.4 2004 with around 75000miles on the clock.
Any suggestions welcome.
  • 3 years later...
Hi there sorry to drag up an old post. I have all of the above issues but the vehicle wont drive . Did you figure out the issue? I
Hi Chris,
I have the same problem since a month ago. I noticed that when the VSC light comes on, it comes on together with the check engine light and check hybrid red car ! light come on. It can only be the VSC problem speed sensor problem or gas cap or tyre pressure. Once the VSC is fixed, the other two lights goes away. I haven't fixed it yet.
I can feel my hybrid battery is running and being charged so I think this is a design issue. Can be just a simple issue
It happened before some 2 years ago but with the 4WD light on. The w/shop guys will give you different opinions and I ended up first changing the HV inverter and after driving a short distance, the lights came back. They next changed the pump for the hybrid radiator and it never came back. So I think it was not the HV inverter but just a simple pump issue. What a price I had to pay.Error10Sept2022.jpeg
Edited by taifansi
Many thanks
Gabriel
Hi Gabs. Can you share if you managed to resolve this issue? I have the same problem and symptoms and the car stops two time but starts up.
Also how do you know when the hybrid battery is charged when the 3 lights are on? Thanks!
Edited by taifansi
Thanks for that bud. Mine wont even turn the engine on to charge the battery. Ive had several computers on it but none seem to be able to pull any live data. Im close to checking battery cells manually. Im actually a HV tech for ford but I'm stumped with this one with no real direction to follow . Will be sure to update if i figure it out though
You mean this....
You can find some on youtube, like this one..
https://www.youtube.com/watch?v=2YYsTWLTyY0
Edited by taifansi
If the 4WD, VSC, and hybrid warning light (car with exclamation mark) are lit the most likely cause is a hybrid fault, not a VSC fault. If they come on after a period of driving a common issue is the inverter coolant pump isn't pumping and the inverter is overheating. Whatever the issue, you need Techstream to find out what the codes are and to get live data.
Edited by smurf
Right on Smurf! But my stupid mechanic blamed it on the inverter and changed it. After driving around a couple of miles, all the 4 lights came back on. He changed the pump and the fault cleared. This was 2 years ago. It cost me alot.
Just about a month ago, this time 3 lights came on. The VSC, Check engine light and the check hybrid light. This happened when I noticed the aux battery went dead several times and I kept charging it and finally I change to a new battery. The cars seems to be running good but I couldn't clear the lights. The hybrid battery seems to be kicking in when idle but the energy display usually stops working when the check hybrid light comes on. Any suggestions?
The only suggestion I can offer is to connect up with Techstream and read the codes. It could be absolutely anything.
