sliding door cable replaement
Hi ALL,Merry Christmas.
My sliding door right side, is very stiff to operate, think the cable needs replacing,  are there any tutorials on this?
Thanks,Ken.
Hi Ken, I have just replaced my passenger side door cable. You need to ascertain if it is the cable that's broken by looking at the cover under the rear side window at the bottom. I bought a cable for 329 from my local Toyota dealer and took me 4 hours to fit. look at a lot of YouTube videos like this .
I did my R sliding door cable last weekend. It is easy to do but get the right tools, from what I remember
10mm spanner or socket
JIS #2 screwdriver
T40 torx
T25 torx
get some panel removal tools, don’t use a knife or screwdriver! Get some spare panel clips too and zip ties.
take photos of it all as you undo/remove, this will help greatly in putting it all back.
take your time, do it well do it once.
Important: only remove the white plastic cable cover once you have passively fitted the cable reel to the spline.
Dab a little bit of fresh silicon grease to the splines.
fit the bottom (black) cable end first, then the upper/rear (grey) cable end last; try to keep a little bit of tension in the cable and ensure it stays tracked in the correct line. you will need the T40 torx to unhinge the upper cable hold, slot the cable clip in, then lever it back and secure with the same T40 bolt.
there is a small black plastic cover over the upper cable hold; you need to slide this forwards but it takes some effort. Put a cloth over it, put a socket extension bar on it to act as a drift, and then tap it with a rubber mallet. Repeat on reinstallation to make sure it is fitted properly.
Hi All;
I took my sliding door panel off (passenger right hand) because it wont open with dash button or fob. It closes fine. I noticed that the cable from the door handle to the latch at the back of the door is not working properly. If I pushed the lever near to the handle and then pressed the fob it worked perfectly. I also noticed that the cable had come separated from the crimped end at the rear latch operator. Any Idea of part number or where I can get a new one from. Alphard Hybrid 2.4 2005.
Thanks in advance 😁
forgot to add it opens perfectly from the outside using the handle
Edited by atlanticcobra2023
added info
Hi lovely people.  Purchased a new sliding door mechanism/cables from kohaku.shop.They are a Japanese company trading through eBay. It took six working days to get to me. Not a bad price and excellent service.
Fitting went well, a bit of a squeeze to get the cables up to the hinge. I supported the bottom of the door and slackened the hinge this gave me a bit more wriggle room.  Hope this helps someone in the future.
hi
i need to purchase just the cable for my 2007 ah10, were can i get this from?
Hi Everyone,
Am I right in thinking that my 2006 2.4 Anh10 is not fitted with electric sliding doors from the factory?
Can I retro fit the motor mechanism with an available kit?
Any help welcome.
1 hour ago, Pete S. said:
Hi Everyone,
Any help welcome.
Do you have door buttons on dash to right of steering wheel, and door power button to left of steering wheel. If you have these press the door power button it my be switched off. If you don't have these then may be you don't have power slide doors
typo error
Yes I do realise there are no power buttons. It’s just that when I close the doors manually and slowly , as the catch engages the rear end of the door closes with an electric motor. So I was wondering if there is a way of adding the electrical kit needed to power the opening and closing action as in newer models.
  • 5 months later...
Hi folks, my door cable mechanism has arrived (good price and quick delivery from "kabuki")
Does anyone have a link to a video of someone replacing the cable please? I've seen the video in this thread but unless I'm wrong the guy is replacing the motor not the cable and I would like a video to follow as I'm not that technical but willing to have a go.
Dave
  • 4 months later...
My drivers side cable jammed and snapped, so looking to get this fixed.
How did you get on, any videos or info you could share?
Hi folks, my passenger sliding door cable snapped off from inside the door sealer. I've never seen a cable or wireless cable inside the sealer before. I can't open or close it with the keys or door handle or dashboard button. Its there anyone had the same problem?
  • 4 months later...
hi folks, i have just replaced my electric sliding door cable on my 2006 toyota alphard anh10 as it jammed and broke, but now its good. however i need to replace the black operating cable from the handle mechanism going to the rear lock, any ideas where i can get one.
