Workshop manuals for 1st Gen (holy Grail?)
On 12/12/2022 at 1:51 PM, dugii said:
I found scan of service manual, unfortunately it's in russian, and not easy to translate but looks really comprehensive and it has wiring diagrams as well.
I've just found this.  Believe me its worth its weight in gold and may have already answered how to get the plastic inlays out of my wheel arches.  Did anyone ever find an English translation?
  • Replies 57
  • Views 17.2k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • AH, forgot the main thing... The website link..   I hope this helps someone, the main page has 5 coloured tabs at top, I think the 1st just reloads, 2nd is maintenance manual, DTC error code
  • Anyone using this? if using chrome, when you finally navigate to the page you need, goto the link in the address bar and remove the part that says '_base'   e.g: http://fsm.japancl
  • I found scan of service manual, unfortunately it's in russian, and not easy to translate but looks really comprehensive and it has wiring diagrams as well. 498521882_ToyotaEstima2000-2006_Alphard_2
Posted Images
FYI this is how I converted the above document from an image scan to translatable text.
  • Click 'Add/Update Languages...'
  • Click 'Russian' then 'Install'.
  • Make sure both 'English' and 'Russian' are selected.
  • Select 'All' pages then 'OK' to process the whole document.
  • Do something else for about an hour.
  • After completion, click 'Save'.
Now just select text in the PDF as you would normally and paste into Google Translate:
Full Russian to English instructions given here:
On 4/27/2023 at 1:20 PM, atlanticcobra2023 said:
It finally arrived and got it up and running in Windows 11. lots of coffee and biscuits for me tonight 😁
Hi Chris
I have this CD but would not install onto my windows 11 computer, so I just had to copy the files manually and open index2.html. I also tried installing it under windows XP, that didn't work either. I have translated most of the disc but some reason the wiring diagram menu doesn't work due to a Javascript function that is missing, I think.
"function FC(WO)"
Can you search your disc to see if is present.
Most of the .gif images in the description section have a .pdf version as well but I can't get this to load instead.
Next is to find a program that will open, translate scanned .pdf files then save automatically!
10 hours ago, Jeza said:
Hi Chris
"function FC(WO)"
I don't have the 10 series cdrom, you need to ask Atlanticcobra2023.
On 7/15/2025 at 11:09 AM, Jeza said:
Hi Chris
"function FC(WO)"
I have a copy of the hybrid manual that is partially translated from Japanese.  I bought it via a Russian website from a guy that only took crypto as payment. That was a steep learning curve 🫣. The website is dead now.
Anyhow, I'll fire up my laptop later and see if it has the file you are looking for.
Thanks, but I have adapted a script from another menu .html file and now the wiring menu works.
Sounds a bit dodgy buying from a Russian in crypto 🤔
Not as bad as it sounds. It looked like a Russian enthusiast run website that originally offered the manuals with payment via PayPal, and the Ukraine invasion stopped that method of payment. I took a punt for $40US and it worked out fine.
The website has gone now, but this is it on the internet archive https://web.archive.org/web/20230326174700/http://en.estima.su/
