I NEED A REPLACEMENT KEY FOR MY ALPHARD.. CAN ANYONE HELP. THE VEHICLE IS AN IMPORT
Hi.   I was in the same situation and got another key cut with ease, but impossible to obtain another programmable fob.  However, by opening the driver's door, the alarm goes off but as soon as the engine starts all is silent and you can drive away with no problem!  Hope this helps.
YES. I HAVE ONLY ONE KEY...
HI QUELCH HERE.. THANKS FOR REPLY. CAN YOU TELL ME WHERE I CAN GET BLANK  AND THEN GET IT CUT PLEASE.....?
Hi Quelch, I bought a replacement key from ebay ;    https://www.ebay.co.uk/itm/Replacement-Remote-Key-Fob-4-Button-314-3MHz-4D-Chip-for-Toyota-Alphard-2005/331576219346?epid=841823142&hash=item4d337b96d2%3Ag%3Aq7UAAOSw87RaqM28&fbclid=IwAR3u9ufypXYFlv1pKU1IG7llXfGsIYaK1lLtfLpD_3UqN0KkAIpkxPVc2Sg
programmed the remote easily, using instructions off off the net, and bought a Toyota Smart Keymaker to add the new key to the car ecu.
You can get the key cut at any reputable heel bar. Cost in total , about 40 quid. PM me if you need more info
Nick
Edited by Nick K
i Quelch.  Go to keytomycar.co.uk and speak to Paul on 07884 285570 - he's based in Barnstaple.  I'm sure he will know someone up your way.  Good luck.  Patrick
HI again.  Meant to say that Paul had a blank on site so just had to cut it and test it.  I'm sure he would post you one
QUELCH SAYS MANY THANKS FOR YOUR HELP AND CONTACTS TO SOLVE MY KEY PROBLEM
