ANYONE HAD TO RESET THE WINDOW SWITCHES ON THE DRIVERS DOOR FOR OPENING CLOSING OF THE OTHER 3 DOOR WINDOWS. LONG WINDED BUT JUST HAD TO DO MINE.
Have you tried any of the Toyota door lock videos on utube, i've just looked and a couple of them are the same for different Toyota models.
If power from the battery has been interrupted (disconnected) you'll have to operate each window from the corresponding door, all the way down then back up, before drivers door controls will work again.
Hope this helps.
