Alphardy Posted January 1, 2020 Posted January 1, 2020 Hi attempting to fit a Xtrons head unit. I have done most but have got stuck with the reverse camera. The Xtrons comes with 4 loose cables that are supposed to be connected to the loom: Reverse - Break in - F-CAM 12v - AMI Com - Which of these do I need to connect? Also where do I connect them to? I have 2002 Alphard G. What I have found is that pin 5 on this connector (90980-11909) is reverse: I assume that is where the XTRONS reverse cable goes into. I have purchased an adapter for the factory camera : Where would I connect that red cable to, would it be to switched ACC? to the reverse? And, do I need to still connect the F-CAM? Thanks.
SupaDave Posted October 1, 2021 Posted October 1, 2021 Hi mate, bit late to the party I know but did you manage to sort this problem?
Register a new accountSign in
