Hi attempting to fit a Xtrons head unit.
I have done most but have got stuck with the reverse camera.
The Xtrons comes with 4 loose cables that are supposed to be connected to the loom: PSD60HGT_30.jpg
Reverse -
Break in -
F-CAM 12v  -
AMI Com -
Which of these do I need to connect?
Also where do I connect them to?
I have 2002 Alphard G.
What I have found is that pin 5 on this connector (90980-11909) is reverse: pinout_869900067_1.gif
I assume that is where the XTRONS reverse cable goes into.
Where would I connect that red cable to, would it be to switched ACC? to the reverse?
And, do I need to still connect the F-CAM?
Thanks.
Hi mate, bit late to the party I know but did you manage to sort this problem?
