Hi, I've just joined.
I bought an Alphard a couple of days ago for my daughter who lives in Bristol (BS1). I'm keen to find local support for her...
I've just gone down and setup a code reader tool for them which reads all alphard codes, its a really impressive tool.
It can rewrite ecu's, re program keys, and does alot with terms of alphards compared to the other tools on the market. :)
What code reader can you use on a 2004 2.4 Alphard
l have tried several but none will talk to it.
Got an elm327 now and that’s the same.
ah that's where it becomes sticky. I use elm327 with Torque on android then input a advanced variable for the 3L but don't know the advanced variable for the hybrid i'm afriad. I setup a bristol garage with a very expensive bit of kit which does it all see if i can find the variable and get back to you.
Hi
One of the door close cables on the central nearside electric doors has had the plastic coating stripped and is jamming the door. Is there somewhere in Bristol I can get this repaired.
